Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: "stop on"
    Dec 2011
    Los Angeles
    Default "stop on"
    I recently had a power outage to the breaker panel that feeds my shopbot. After having an electrician look over the panel I have powered on today to find that the 3-button pendant is not working properly. The number for input #4 is RED. When i release the E-stop and press the reset button input #4 becomes highlighted, but the number itself stays RED. Output #4 then turns off. When i attempt to utilize any kind of motion i get a warning that tells me to "reset the stop button." Also, after i press reset i get a warning graphic in the control window that say "STOP ON" in red and yellow.
    I have checked the box, everything is connected properly as well as nothing seems to be damaged from the power outage. Does anyone have an understanding or experience with this issue?
    Feb 2013
    River Fall WI
    Had this happen.
    Try redownlaoding your drivers.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Oct 2011
    Colorado
    Most of the limit switches are on the same circuit. Run the machine past your x and y limits and the one that is stuck will likely unstick itself.
    Dec 2011
    Los Angeles
    I have uninstalled and reinstalled the control software. I have run all of the updates and still no change. Since i cant get the gantry to move I used a wrench to trigger the proximity sensors which reset the stop/reset temporarily in the software, but overall didnt change anything. When i release the E-stop and press "reset" button i still get the "Stop On" icon in the control window along with Input 4 still having a red number and input 3 having a yellow number.
    Delray Beach, FL
    Kenny: It sounds like a wiring issue. Make sure all your leads, especially the grounds, are properly secured at the control box again. Make sure you do not have a pinched line somewhere between the switches and the control box.
    I assume you have shut everything down, left it off for 30 seconds or so, and rebooted.
    Make sure your number 4 input for the E stop is set correctly in values VN my defaults to normally closed but my stop is normally open also the limit inputs may be wrong You could go into tools and run the setup.
    Feb 2013
    River Fall WI
    How often do you use your estop?
    If it is almost never you may need to clean/fix the button.
    This also happened the first time we hit the estop after the bot was sitting for a long time.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Dec 2011
    Los Angeles
    Thank you all for you help and input. Ultimately I had to reset to factory settings. Something with the power outage caused causing the system to shutdown improperly resulted in the default values being reset and some options no longer available to manually reset. With the factory reset everything is back up and running.
    Feb 2010
    SOUTH CENTRAL COLORADO
    Default same issues
    My router wont start when i load a tool path. however if i do the command SO 1 it runs fine. starting like it should and stopping like it should. The input lights 2 and 3 are both red and green. If i hit the estop it flashes bright red
    I half way think that the problem is in my key, but i dont know that for sure. Everyone keeps talking about a reset button in the control box of the buddy prs, but where is it.
    Any suggestions?
    Do a tr command and click on the rpm and see if there is a 1 in the set up sheet
  1. Selling: Shopbot 2016 PRS Alpha 48"x48"-12"
    By rohit in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 08-11-2016, 05:01 PM
  2. PRTALPHA 120 X 60 X 6, w 3HP Colombo, 6" Index Head w 18"x18" x10' alcove in table
    By PVWoodworks in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 08-12-2015, 07:09 PM
  3. Breaking Bits After an "S" stop and "R" resume
    By cabindoors in forum Troubleshooting
    Last Post: 12-17-2010, 05:34 PM
  4. Getting "Missing Comm" or "Communitation Error"
    By dengler in forum ShopBotter Message Board
    Last Post: 07-02-2010, 04:22 PM
