Hi,
I would like to make the wedge top for my ShopBot Desktop using the spoilerboard included with the machine. I have downloaded all the files from here:
https://app.box.com/wedging-top
- In the file named "Desktop mdf wedging top.crv" it shows the entire cutout of the board to be sized at 28.5"22.5". Does anyone have a VCarve file that is specified to 24x"18" for the Desktop only using the spoilerboard that the machine came with?
- I also noticed the dowel holes toolpath is set at cut depth of 0.78, whereas the spoilerboard is 3/4" thick. Wouldn't the bit cut through to the aluminum rails?
- Which bit(s) would you recommend using to cut? I have the ShopBot Desktop Starter Bit Kit (13698).
Thanks in advance, sorry for the novice questions!
