Greetings,
I apologize if these are super noob questions, I'm still a little iffy on what gcode gets converted properly to SB and what gets discarded or misinterpreted. I've been having a really hard time with some Mastercam X6 (generic mill) WYSIWYG vs ShopBot 3 preview/WYSIWYG visualization inconsistencies, and I have two questions:
1. Does the shopbot Preview always assume top of stock is zero? I almost never set zero to TOS because I use material that is really inconsistent in its thickness and I want to make sure that I get the breakthrough that I need. The SB preview always shows the tool going through my stock from the machine origin to get to the first cut. I have cut a handful of parts, and didn't have any problems (I also, as I have mentioned in previous posts, have run a similar CNC router for five years with Mach3 prior to getting the Shopbot), but now that I'm regularly using the Preview tool to check files (after a crash) I'm starting to second guess my programming.
2. Does the shopbot not recognize something about gcode drilling operations, or something about planes or coordinate systems? I'm using a Default Mill post processor inside of Mastercam and the following code is supposed to drill two holes. Does anyone see anything that is unsupported code in the following routine:
I'm just trying to get a handle on what I can and can't do in terms of programming, I'm afraid of generating code that is not recognized and losing valuable material or destroying the machine. Everyone that I talked to at SB prior to purchasing this machine said that it runs gcode fine, but compared to Mach3, it seems to be missing a lot of stuff, and that makes me really nervous.( T62 | 1/8 DRILL | H62 )
N100 G20
N102 G0 G17 G40 G49 G80 G90
N104 T62 M6
N106 G0 G90 G54 X5.6012 Y6.315 A0. S2139 M3
c6
N108 G43 H62 Z.75
N110 G98 G81 Z.1325 R.6575 F4.11
N112 X10.3988
N114 G80
N116 M5
N122 M30
Thanks in advance for any words of wisdom,
Aaron
