Thanks for the input Brady,
IF the machine's specked at +- 1/64" over length then have I reached it's point of diminishing returns?
By spinning one of the boards around and placing it next to the other one, isnt any resulting gap between the boards a doubling of any deviation from a straight line? If so, then it would seem that I have gotten it as far as factory tolerance? The pic of the MDF cut results show a gap in the middle of the two boards (one of which was spun 180) that is apx -1/32". Divide in half and were at the 1/64" deviation from straight. Would this mean then that I'm out of the rain and on the porch as far as the house of shopbot PRS is concerned? Do you think it could get better than this?
Also, with respect to the rail dip, I had to take out shims after it was found that the middle sagged and the middle feet had to be lowered. One side needed none whereas the other side needed a couple of shims still between the middle and end legs. I think the MDF test cut board comparison picture show what had to be done to that one rail, shim wise. Does that look like typical shimming?
As far as the X table rails being bowed, even if that were the case (and I will check on it now that the thought is in my head) wouldn't the amount of 'slop' in the mounting of the X rails to the top of the table rail allow for any deviation here. If the X rail is straight to the fish line then would that take any 'bow' of the x rail out of the equation?
Machine does run improved now and you can hear it in long X jogs. Noticeably less rumbling and more evenness. Still, if it can get better than this and stay put after getting it there then I'm game to keep going.
Thanks for any insights into this dialing effort from this board. It's greatly appreciated.
Tim
