I had been having problems with my ShopBot Desktop slowing down and then stopping in the middle of a cut. I disabled USB power management and that seemed to go away. However, now the it seems like the ShopBot is loosing the X position.
I was engraving an acrylic piece using a spring loaded 90 degree diamond drag bit with the spindle off and no dust collection attached. The job ran for 1:35:05 without stopping. The attached pictures show the following problems:
- The hatched area is not consistent. The acrylic is not flat (0.002 difference from the thinner left side to the right), but the spring loaded bit should take care of that. I set z-zero to the top of the acrylic. The engrave depth/pressure setting is 0.01 and the fill stepover is 0.004. Feed speed is 1.4 inches/second.
- There are vertical lines in hatched areas that should not be there.
- After the ShopBot finishes hatching an area it outlines the perimeter. It is clear in the pictures that the outline on the right has move about 1/8" to the right.
Any ideas as to what is happening and what I might do to fix it?
Steve
