I've discovered this doesn't take any special skill or training.
If you want lightning bolts of static electricity to jump from your toes through your shoes and into the concrete floor, just use a shop vac to clean up the shavings and dust from cutting Azek PVC sheets.
I can't imagine what the voltage is when this happens but the spark has to travel at least two inches.
I've also discovered that even though my Shopbot is grounded, if I attempt to do any manual cleaning of the PVC chips while the machine is running (I do not have vacuum dust/chip removal at the router) and static discharges from my arm or hand to the rails, it can cause the steppers to hiccup. This happened while using a metal handled broom (not the shop vac) on the material while the machine was cutting.
I ruined about 10 parts and 3/4 sheet of material because it changed the Z height, I didn't realize the parts were not completely cut through, and I removed the sheet from the machine. It was impossible for me to register it in the exact same position because I use screws to hold down the sheet, and tabs to hold the parts.
I'm just glad I didn't blow out any drivers!
So now I don't clean up anything near the machine while the job is running and when I do clean up, I shut off the control box.
