If someone would like to go for re-grinding their rails with an angle grinder then they are best off making a jig for the grinder so that it runs consistantly. There is a "do-it yourself" build a cnc forum that tells how to do this. I have not done this but have heard that it works well. www.mechmate.com
When buying the "complete upgrade kit" from SB you get a lot more than just the hardened rails. There is a lot of precision drilling/countersinking, and tapping required on the pillow block to do it right. I upgraded my prt rails, y rails first (which was pretty easy to adapt right onto the existing angled rail but touchy to adjust perfect), and then x rails when I upgraded the gantry as well. I did it as diy project by starting with an extrusion and then a 1/2 thick pillow block with the hardened rails mounted to it. It was quite a bit of work, although for me it was a pleasant "tinker" project break from the normal cabinet work.
