When the red stop button is pushed, it stays pushed in and you need to twist it to let it come back up. Then you need to turn the power off to your control box, and your computer. Then go to your power supply (circuit breaker) for the bot and turn that off.
The reason being is sometimes some settings get stuck in the memory and keep you from resetting things. Keep in mind that all your settings of X,Y,Z will be lost and you need to reset them.
Words of Wisdom:
