Results 1 to 8 of 8
Thread: Finger Jointed Crate
    Oct 2010
    TX
    Default Finger Jointed Crate
    So, this is my idea of what we should be doing with scrap plywood lumber. This is a small crate I decided I needed for a customer's project. Made it in a jiffy on the ShopBot. Not completely original, but Very very functional! And the joints were so tight, I was tempted to just staple it and forget about it. I DID pull it back apart and glue, then staple. It is a fantastic little crate.
    See pics.
    My first thought was that if you made the Dogbone oversized, you could have wide range of proportional box sizes, simply by grouping and resizing,
    Infected tooth is making it hard to think though(tougher than usual. Should work?
    Thanks for posting
    Cleveland TN
    Looks like a really cool project, would you want to share the files? I see a dozen uses for this along with cut handles in the sides....
    Joe
    2005 PRT Alpha 48x96
    2013 Colombo 3hp spindle
    Indexer (converted lathe)
    Aspire 9.0
    Worth VCarving "Shipped by:..........................." on one or more panels as it certainly won't be tossed in the trash bin!
    Never know where jobs are going to come from
    Oct 2010
    TX
    Scott,
    I very certainly am considering V carving when it gets back from the vendor (on the "lid").
    Already cut two small slot holes in the lid to facilitate controlling it during lid removal.
    Sorry to hear about the tooth. That can affect everything you do.... get better!
    Monty
    Oct 2010
    TX
    Joe &
    (Scott) Yes. I had thought about scaling it in order to meet various needs.
    (Joe) I would be happy to send you the file. I use Aspire 4.5. So you would have to have that version to use my cut files (even just to modify them).... but I am willing to send them to you. ( I don't know if the forum has allowed us to share files on here...)
    It was a bit of a PITA to do all the corner clearance set up. I learned why I could not do standard fillets with Aspire while chatting with TJ during his training this week... that will speed up the next one tremendously....
    But let me know if you need a dxf so you can import and set up your own cut files. (mine is set up using an onsrud 1/8" bit. I think it is a 63-712(?). And files would be in Aspire 4.5. Pretty simple. Just tedious to do the drawing part of the set up!
    Monty
    Cleveland TN
    Monty,
    Sent you a PM, thanks again. I need to watch the last 3 training sessions, my day job has kept me too busy to watch them live let along watch later.
    Joe
    Aspire 9.0
    Monty, knew I'd miss something in the Q&A, but Dad was here.
    Amoxicillin 1/2hour ago and 102F temp--2+2=3.14159.... see I'm better already!
    More intelligent comments later. (Maybe)
    Need to print out shortcuts again for laptop. Control-Y totally spaced it the last month and could have saved hours. Need a brain implant
    "Warning!!! Designed when tired!!! " It should be my logo
  1. Another finger box project
    By tlempicke in forum ShopBotter Message Board
    Last Post: 10-07-2016, 06:58 AM
  2. Wood finger jointed turned bowl
    Last Post: 10-04-2016, 08:39 AM
  3. 1st Finger Joint Box
    By Tim Lucas in forum Folder 2014
    Last Post: 12-10-2014, 07:31 AM
  4. Egg Crate
    By MogulTx in forum Aspire
    Last Post: 07-04-2013, 04:27 AM
  5. OMG that's a big crate!
    By Acmeaviator in forum ShopBotter Message Board
    Last Post: 05-27-2011, 12:06 PM
