When cutting pine I seem to run about 80 degrees and perfect cuts, I switched to MDF with the same feeds and I'm running about 120 degrees, its warm when I grab the bit... is this normal?
Its set about 2.17ips at 13k rpm which is taken from the onsrud techs recommendations for their chipload and 1/8" pass depths
I'm using a 2" 120degree onsrud Vbit.
