Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: contact cement
    Mar 2005
    Cabinets Plus of Augusta, Hephzibah Ga 30815
    Default contact cement
    What is the best way to apply contact cement?
    I priced a canister of cement hose and gun but it is around 550.00 That will buy a lot of 5 gal pails and I was interested in what others do . Thank you
    May 2014
    Detroit MI
    Spray gun and 2 gallon pot. We sometimes spray 10-15 gallons a day this way. We use Binks 2001 guns.
    Also, by buying five 5 gallon cans at a time, we save about $20/can over buying single 5 gal cans.
    Delray Beach, FL
    I use a siphon pot and buy it by 5's. Those precharged canisters are pricey and IMHO are only worth it for a field job if you can't lay your hands on a larger portable compressor. You can get away with the cheapos at Big Box or HF but there guns aren't as good as the pro varieties and you will get some that dump fast. I just picked up a couple at a local wholesale supply house for around 45 each and they spray clean.
    Oct 2010
    TX
    Are you guys using the flammable variety or the non-flammable style.... ( I have a process that requires the stout stuff.) I would be interested to see how well the stuff sprays. It would reduce my labor a great deal. We currently brush apply, due to the structure that it goes on to....
    Delray Beach, FL
    The correct spec product, whether low emission, water based, or solvent based, all spray fine. It's not rocket science. Talk to any commercial supplier (except the "customer service order takers" who don't know squat).
    Oct 2010
    TX
    Thanks Dave.
    I will check with my floor products supplier ( who sells me the contact cement that we use). And will ask him about spray tech for this type product. Thanks for the post!
    Monty
    Mar 2005
    Does the water base do as good as the solvent base or does it spray better?
    My suppliers tell me that they have a red or clear but have said nothing about water base. is there anyone who uses the siphon cup guns? what is the best thing to clean up tools and such with Thank you
    I don't use contact cement however it would seem to me that even if you have to pay more for it you would be better off buying it in smaller quantities then the $550.00 size because if something happens like weather or something where you don't use it for a long time and it goes bad you won't lose hundreds of dollars.
    Words of Wisdom:
    I worked for a company that had several canisters for spraying as they had maybe 4 or 5 people spraying at a time. The other place had the spray pot set up but you had to take your work over to it and some of it was pretty big to move about. As for it going bad I have a canister that is about 3 years old now and almost gone but still good. the 5 gallon buckets would have dried up by now.
    Jun 2014
    Virginia Beach, Va
    5 gallon bucket and cheap quart cup conventional spray gun from Northern Tool. I thin out the glue slightly to spray finer.
    PRS Alpha 96-60
    HSD 4hp Quick change spindle, HSK toolholders
    Air Drill
    6 zone vacuum table
  1. Spray Canister Contact Cement
    By john_l in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 05-22-2010, 02:41 PM
  2. Foam safe contact cement
    By john_hartman in forum ShopBotter Message Board
    Last Post: 08-13-2009, 09:17 PM
  3. Rubber cement masking
    By ilsaarin in forum Sign Making
    Last Post: 07-17-2009, 03:54 PM
  4. Texture surface on Cement
    By butch in forum Archives2008
    Last Post: 09-08-2008, 10:18 AM
  5. Contact Cement to glue spoilboard
    By bakerkr in forum Archives2007
    Last Post: 04-22-2007, 01:02 AM
