There is... move faster, as Brady suggested. That squeal is due to going to slow and/or turning too fast. So slow down the RPM, or move faster.
OR - drop a flute (ie, go from a two flute to a single flute)
I typically run solid wood (all species of hardwoods, but a lot of hard maple) at 3 IPS and 10,000 with a 1/4" spiral bit as my default. For 3/4" stock I'd do two passes, perhaps three max but if you really want to get a clean edge then run a few passes in climb mode, leave about 1/32" at the bottom and then go back and do a full cut through pass in conventional cut.
Then fine tune the speeds and rpm to suit. With small pcs, you cant really go faster than a certain speed due to the ramp time, and the fact the machine is constantly accelerating and slowing down to change direction.
That works best for me, and was advice I was given here when I started.
I always do my first pass(es) in climb, leave a bit of material left and then do a full final pass in conventional cut direction.
Make sure your bit can cut the full thickness though, but most of my 1/4" bits have a 7/8" length of cut.
The reason this works in that when climb cutting, the bit wants to ride up, and away from the line of cut (the small amount of slop in the drive allows some movement) while in conventional cutting the bit is pulled into the cut. You can see the small step in the waste portion of your material after you cut this way.
