Results 1 to 10 of 15
Thread: Turning off spindle before changing bits?
    Dec 2014
    Los Angeles, CA
    Default Turning off spindle before changing bits?
    For safety reasons, is it a good practice to turn off the spindle (by turning the key) before changing bits in between cuts? I'm paranoid that the spindle will accidentally start when I'm changing bits
    Yes. This is why the key is tethered to one of the wrenches.
    Dec 2014
    Los Angeles, CA
    They forgot to include the spindle key with my Desktop so the key was shipped separately. Do you have a photo of how the key looks tethered to the wrench? Did it come this way with all the Desktop models? I suppose I'll tether it myself...
    Here you go M.
    May have changed slightly as this is the first one Gordon Fabbed(Kirk got second and got a flat key like yours).
    Scott Plaisted
    2013 Desktop/spindle/VCP 9
    Dec 2014
    Los Angeles, CA
    Ahhh, got it! Thanks Scott for the photo
    Aug 2012
    Davenport Iowa
    I have a PRS Alpha that did not come with a key. Is there an upgrade?
    I would add it
    Life is like a project you continue to work on until it's finished.
    Never start a project you don't intend to finish!
    Ken, When I initially asked about it(and then they fabbed it FOR FREE-Way to go Shopbot ) ,it was because I'd seen that some of the bigger machines had it and I thought it was a great feature for what we thought at the time would be the work environment.
    I thought all the newer ones came with it.
    Rereading, i see that Russ and John mentioned it was on "Newer", so not sure when it became a"standard feature".
    http://www.talkshopbot.com/forum/sho...ndle+interlock
    Call Shopbot?
    Scott Plaisted
    Sep 2009
    Surrey, UK
    Mines a 2009 and it came with the key interlock.
    Mar 2009
    Pope Valley CA
    Ordered my PRSAlpha in 12/08 - no key interlock, but also no problems.
    Ron Sloan
    Sep 2008
    Quote Originally Posted by bradywatson View Post
    curious to ask, why is there the need to cut power to spindle during a bit change? What would cause spindle to start alone other than a software glitch?
    Vector Studio 22
  1. Trouble turning spindle on
    By cjorgensenmd in forum Designing and Creating the sbp cutting file
    Last Post: 01-08-2017, 01:36 PM
  2. Changing bits = loosing zero
    By signtist in forum ShopBotter Message Board
    Last Post: 07-08-2012, 02:23 PM
  3. changing bits
    By moojo in forum ShopBotter Message Board
    Last Post: 10-11-2010, 11:16 AM
  4. Spindle Not Turning On (3.6.1)
    By nat_wheatley in forum Troubleshooting
    Last Post: 11-29-2009, 04:41 PM
  5. Changing bits
    By pross in forum Archives2007
    Last Post: 10-12-2007, 10:16 AM
