I know a lot of you guys have home shops out back and some may be facing my situation of needing to get Ethernet out there but either not wanting to bury a cable or out of range of a cable (over 100m).
In my case, burying a cable was prohibitive (though not impossible) due to underground power / phone / water lines / sprinkler system that was already installed when we bought the place (that means I have NO IDEA where some of the lines run). The best run I could find meant I would be crossing the existing waterline and the sprinkler system who knows how many times.
My solution was the NanoStation loco M5 by Ubiquiti Networks (ubnt.com)
Each station is about $70 at Amazon and I used the available window/wall mount kit. They are both outside (as these are supposed to survive outside) Currently they have 113 reviews 100 of which are 5 stars.
I installed one on the house under the eave and the other on the front of the shop wall. Pointed them at each other (I used a laser pointer to make it quick) and powered them up. On the house I set a static IP address and set it for Access Point WDS, on the shop I set a static IP with the mode Station WDS. That made a transparent bridge. I then put an Almond Wireless access router on it in the shop and BOOM, wireless (and wired if I want it) internet in the shop.
If you haven't seen the Securifi Almond - Touchscreen Wireless Router / Range Extender it is available on Amazon as well.
Not trying to be a commercial here, I get no kickback on these things. I just found something that works and works well and wanted to share for those that might need a solution but don't know where to look.
/RB
