Machine ramping while using indexer
So I just got my new 6" indexer connected to my machine, after speaking with shopbot support to find the correct unit values (mine was not programmed leaving shopbot Hq) I have it working. I am currently cutting a quick test file/ piece of wood.
I started with a 2.75" X 2.75" rectangle length of wood and chucked it up inside the jaws, and also found the center point with the crossed lines.
I programmed the pocket cut file using aspire 8, and have it cutting a raster path, parallel to the X axis, which is how my indexer is set up. everything is zeroed, centered, yatta yatta.
What I am curious about is the ramping of my X axis. As the machine is going back and forth, the X move speed was not input from my programming, and neither was any ramping. I have my move speed set as default 5 ips. my program called for 2ips with a .05 DOC which is pretty small, but as this is my first time doing ANY rotary work since high school i'm babying it for now. depth of cut and the program as a whole appear to be good to go, but the machine is banging back and forth on every raster as it stops and reverses directions. I Lowered the move speed manually mid-partfile to the appropriate value, but still no ramping is present....
Any Ideas guys? thank you
PRS Alpha 96" X 48" w/ 12" Z
6" Indexer
Aspire 8
