Results 1 to 6 of 6
Thread: Broken control box switch
    May 2010
    Chardon, Oh
    Default Broken control box switch
    Need advise on how to open the control box after the power switch has failed.
    If it's an Alpha there is one; Standard there are two - flat slotted fasteners that keep the control box shut. Just pull a coin from your pocket and turn each a 1/4 turn to open.
    Call SB tomorrow for a replacement, if that one cannot be repaired.
    May 2010
    Chardon, Oh
    Thank you, but it appears the slotted plastic outer ring is free wheeling with no grip.
    PRS Alpha
    cnc routing, portland or
    the PRT had that problem mine broke off after th first few times.
    Mine broke day one!
    If yours is like mine, the screwdriver slot below it is the head of the cam lock inside… see photos. The big red knob is the electrical interlock, and not the cabinet lock. You can operate the interlock with the door open, just remember the power inside is on if you do!
    May 2010
    Chardon, Oh
    Thank you for the help full insight. I removed the yellow cover plate, the retaining screws and outer plate. I was then able to insert the control knob and operate the power switch.
  1. Remote control light and timer switch
    Last Post: 11-22-2012, 06:48 AM
  2. Is my bot broken?
    By twelchPTM in forum Assembly & Maintenance
    Last Post: 08-31-2012, 12:47 PM
  3. first broken bit
    By sokwanho in forum ShopBotter Message Board
    Last Post: 10-07-2011, 04:34 AM
  4. control box main switch left on
    By Ronnie Hubbell in forum ShopBotter Message Board
    Last Post: 06-15-2010, 11:57 PM
  5. Broken on/off switch on door
    By myxpykalix in forum Archives2006
    Last Post: 09-21-2006, 11:00 PM
