I'm trying to cut 2" diameter holes into planks of laminated 3/4" plywood. The issue I'm having is that at the point where the cut ends and the waste material breaks away is causing a little chip in the laminate on the good material. I've tried using 1/2" bit and 1/4" bit and adjusting the feeds speeds and plunge rates and I just can't get it to leave a clean cut. I can't use tabs in this situation.
Any ideas/suggestions?
