This was a thread about canister contact cement
http://www.woodweb.com/cgi-bin/forum...pl?read=774323
Also I use only water based mainly i like my brain cells .But its also easier to apply .I only had a problem one time
Water based clear coat is superior to lacquer i can write more why water based is more production friendly below is a graft written 12 years ago .When using a product do your own research find out why its the best NEVER ASK A SALESMAN
I've had a couple of failures on my own projects trying new things
Is Water Based Tough Enough ?
To demonstrate the hardness and durability of clear water-based finishes, Hydrocote conduced a Sward Hardness test to compare Water based Polyurethane to solvent-based nitrocellulose lacquer and oil based polyurethane.
The finishes were sprayed on metal plates and the films were subjected to abrasion from a swinging stainless steel pendulum at interval during the course of a week.
The chart to the right shows the hardness developed of the four products tested. The hardness values given are based on 1.5 mil film allowed to dry at 76�F and 45% relative humidity (Scale: Hardness of glass =100) .
One important note on the test. Water based Polyurethane doesn't reach its full strength until after 30 days. This test was done 4 years ago water based is a lot stronger now.
Hardness: Water-Based vs. Solvent Based
Drying Times Oil based
PolyurethaneWater based
PolyurethaneNitro-Cellulose Lacquer 1 hr 15 3 20 2 hrs 27 8 27 8 hrs 38 22 30 24 hrs 40 42 30 48 hrs 43 56 301Week 45 63 30
