Just an update to my various issues that I have experienced over the past 2 weeks. My shop (35' x 40') is behind my house and was powered from my house (60amp 220v line approx 100'). This presented an issue for me after purchasing my shopbot last summer. I could not run (at least in my mind) another tool comfortably since the bot has a 3hp single phase spindle (30amp), a dedicated vac (8amp) and soon a lighthouse (black box homemade) with 2 motors and may upgrade to 4 motors soon (15amp).
I recently had the power company run a separate 200amp service to the shop and after tidying up the cables and moving the power to the new box I began having issues. The bot would stop mid cut on most files and randomly throw an error really quick that a problem occurred that could not be corrected. I reviewed all the cleanup work I did in tidying up the cables and found 2 motor cables with old nicks and bare wire showing (previous to my purchase of this used machine). I contacted Jeremy @ shopbot and ordered 2 new cables for my X2 and Y motors, installed them but still had the same issues.
I emailed support this weekend and Frank was super nice to respond and go over my issues. He suggested that it might be something related to the usb cable or several other factors so I began that troubleshooting. After several hours of swapping out computers, reloading the control software, etc it turned out to be the USB cable. I replaced it and was able to run a 3d file (attached) as a test and now I am very happy. This is a good lesson to check everything and anything, it could be the most obvious thing that is overlooked because you thought it just couldn't be that simple cable.
Joe
Pictures are of my control panel cleanup and the 3d Angel.
