Background info: We got our Shopbot about a month ago, had the frame assembled in a week (missing/wrong part issues). We then put down our base table layer (3/4 finish ply) followed by screwing the vacuum plenum MDF where the instructions told us to, followed by cutting our vacuum grids and holes and planed it flat. We then used flooring glue to mount the MDF spoil board (which was also planed flat) and ran the plumbing for the vacuum.
Main problem: When we saw an older model demonstrated, it had an incredible amount of suction where the owner placed a 12x12 sheet of ply and we couldn't lift it. On ours, while we can't shift the sheets in the x and y direction, we CAN left the board (4x8 full sheet) off the table. While we thought this would be ok as it would allow us to remove finished pieces easier its proving problematic as the half inch birch finish ply we are using isn't perfectly flat and standing off the table.
There's been numerous discussions as the the possible cause... 1. the plumbing is constricting the air flow 2. Too much glue was used 3. We didn't use the right MDF or should have used a ULDF. Short of planing off the whole spoil boardI'm at a loss.
I'm currently stuck between the boss, warehouse manager, and machine maintenance guy (first two have metal millwork and CNC experience) and I was kinda put into this because I am the most knowledgeable with computers and design work where I am.
Any thoughts and help would be greatly appreciated.
