Thread: Hogging Out - Saving Time - then finish bit
    Nov 2014
    Knoxville TN
    Default Hogging Out - Saving Time - then finish bit
    Ok..so here is a simple question...for some...except for me. I am making a sign for myself and doing a pocket cut. I am trying to speed up the tool paths by running a 1/2 inch bit the first pass and then cleaning up with a 1/8" around the letters where the 1/2 could not reach. I know this is simple but what am I missing. If I choose the same letters and box again, it is just air cutting everything, with the exception of the letters. Should I do a profile around the letters first with a small bit? Thanks.
    P.s. I am still new to this...trying to figure most out on my own...but still get stumped from time to time. Thanks for your patience.
    Nov 2014
    Knoxville TN
    I might have just answered my own question. What I was trying to do was speed up a 7hr job with a 1/8" pocket tool path. I just tried it again. I used a 1/8" bit first, then increased to a 1/4" bit and set those up as profile tool paths. Then I went back and did my pocket tool path with the 1/2 bit. Total down to about 1hr. Is this the best way to do this?
    Feb 2013
    River Fall WI
    If you are using aspire or vcarve you can use the pocket toolpath select your 1/8" bit and then below you can check large area clearing tool and select a 1/2" bit. This will make two toolpaths for you.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
  1. Replies: 0
    Last Post: 04-08-2016, 03:05 PM
  2. Aspire not saving all the time
    By Chuck Keysor in forum Aspire
    Last Post: 09-05-2012, 06:21 PM
  3. hogging out box insides
    Last Post: 05-31-2012, 10:18 PM
  4. Saving as a STL?
    By jim_stadtlander in forum ArtCAM
    Last Post: 11-01-2008, 12:49 PM
  5. Saving in PartWizard
    By Robert Bridges in forum Archives 2003
    Last Post: 02-18-2003, 11:10 AM
