Vac table finished......at last!!
4 independent zones......each 2 x 2'. Reason is that I only have the 2.2hp blower so decided that instead of throwing plastic sheets down to restrict flow I'd use more zones as quite often I only use half the table or less.
I sealed each zone from the other and all round the table. I went to a lot of trouble to make sure the whole system was as airtight as a drum. The rectangular aluminium tubing under the table are held in place with 3D printed (ABS) brackets ....had to come up with a solution for the tight space between power stick and rollers with using two tubes per side.
Preliminary tests are very positive.
With the one zone on it sticks like mud
With two zones open (4 x 2' area) and with a 1 x 1 foot piece of ply sitting in this 4 x 2 area it stick like mud. So that's good as I didn't need to mask off the open space.
But if I start opening more zones then that 1 x 1 piece stops sticking like mud.
If I open all 4 zones and put a 4 x 3 piece of ply on it it sticks well if the ply s flat but if there is a warp in it it won't pull it down.
I think that a 2.2Hp blower is certainly the minimum for a 4 x 4 table. If I had another 2.2Hp blower added it would rock and be useable over the whole 4 x 4 area with any size piece with no masking!! I might just do that yet!
I took a video of my experience with this project and when I get a chance to edit it together I'll post it.
This project is now done and dusted.....
Cheers
