I did a 4hour Diamond engraving on granite and now I hear a slight tick when its rapid start/stops on its hatching but not long strokes
I can wiggle it side to side maybe 1/64"
Is this normal? Should I loosen the nuts and tighten up the pinion?
Does is still make the tick after its cooled down?
Yea this was well after it finished the previous job
Same noise when I wiggle it
Have you tried tightening your pinion gears? They may have developed some slack. Any issues with the cut itself or was it ok?
Everything performs perfect, no issues other than the slack, cuts and engraving is spot on
I will try tightening the pinion
My shop bot doen that what i found was that the set screw had come lose this allowed a slight motion. now before I start up each day. I try to move x, y, and z ... if I have motion I go check that.
www.tgdesigns.net
eking1953@yahoo.com
ST. FRANCIS OF ASSISI
