I have a Jet 16/32 drum sander and find it very useful for many jobs. The sanding belt holds up for a reasonable time with most types of wood. However, recently I did some inlays in oily exotics like Cocobolo and Ebony and find even a light cut of a small piece will clog the abrasive with rings of hard caked and burned-in dust and that way I ruined several belts for good. These in turn will leave burnt stripes on the wood.
I tried one of the cleaning rubber sticks but no luck which ticks me off since the belts are nor cheap.
Anybody knows a trick to avoid that? A slower drum might do it but it is fixed speed.
Thanks, GB
P.S.: Learned one thing....hold on to the rubber stick. It slipped from my hand and jammed between the drum and the housing, stopping the drum from full speed in a fraction of a second. Impossible to move or pull out the squished stick and it took me an hour or so to nibble it out piece by piece. It bent the drum carrier frame a little but fortunately still running true.
