Thread: Y axis end stops and prox switches
    Dallas TX
    Default Y axis end stops and prox switches
    Setting up a PRSAlpha 48X48. The YZ car slides all the way to the left and the car hits the side of the gantry. Obviously this is not correct. The factory was supposed to install the bolts and end stops, but it does not appear they are in the correct position.
    Can someone send me the correct positions?
    I have the bolts set so that it triggers the prox switch when the yz car is about 2 inches from the gantry and the end stops so the yz car stops 1 inch from the gantry.
    Is this an okay setup?
    First-time, so I have no experience. Thanks for the help!
    Dave
    The bolts/targets are NOT factory calibrated. Move them manually so that they trigger just before the mechanical stop. Be careful not to poke the barrel of the sensor out too far or it'll get shaved off.
    To gain extra travel in the -Y direction, remove the bolt and nut closest to the gantry end plate, and slide it all the way back against the end plate. Tighten it up.
  1. Prox Switches
    By jimmya in forum Accessories Setup
    Last Post: 01-24-2010, 07:26 PM
  2. Y axis prox switch and end stops
    By gg_haskell in forum Gantry and Y-car
    Last Post: 11-03-2008, 08:46 AM
  3. Touchy prox switches
    By byoc in forum Archives2007
    Last Post: 12-09-2007, 07:50 PM
  4. What Prox Switches does the Shopbot Use
    By flyguy in forum Archives2007
    Last Post: 03-15-2007, 12:55 PM
  5. Replies: 12
    Last Post: 01-20-2005, 11:51 AM
