Results 1 to 5 of 5
Thread: How do you go about fixing a curve with too many nodes?
    Sep 2012
    Blaine Mn
    Default How do you go about fixing a curve with too many nodes?
    I am wondering if there is a better way than what I am doing,
    which works but takes time. I delete all the nodes except the
    ones next to the straight lines- then make them smooth nodes
    and reform the curve. Thanks Gene
    After reading this I am thinking... the curves I import from my
    vector program are smooth- it is what Aspire generates that
    have all the nodes with straight lines between them?
    Mar 2011
    Marietta, Ga.
    On the Drawing Tab under Edit Objects the third icon from the left is "Fit curves to selected vectors" and you can choose to use arcs or Bezier curves and then preview to see the results...joe
    Jun 2007
    Hampton Roads, VA
    In Aspire there is "Curve fit vectors" under the edit menu. Play with it a bit and you can run it repeatedly to get the node count you re looking for.
    Sep 2012
    Blaine Mn
    Thank you gentlemen... you made my day. I took 10 minutes to get that answer... I love this board.
    Trace over the dirty one on a fresh layer. Then delete the original.
  1. Looking for Help Fixing Fein Vac Hose
    By jdervin in forum ShopBotter Message Board
    Last Post: 07-25-2013, 08:01 PM
  2. Replies: 37
    Last Post: 05-29-2012, 07:36 PM
  3. Text on Curve
    By jimmya in forum ShopBotter Message Board
    Last Post: 03-29-2012, 11:16 AM
  4. Fixing the plexi Cable Carrier
    By applik in forum Archives2006
    Last Post: 11-17-2006, 11:35 PM
  5. Reducing nodes (elements?) in Vector...
    By threadfx in forum Archives thru 2002
    Last Post: 05-12-2001, 12:07 AM
