Results 1 to 4 of 4
Thread: Skipping/Chattering/???, etc....on Y axis movement
    Feb 2015
    Burlington, VT
    Default Skipping/Chattering/???, etc....on Y axis movement
    Hi-
    I just received my Shopbot 42" Buddy and I am having a problem.
    When i travel along the Y axis, to zero on a fixture or part, using the mouse and control panel on the computer, as soon as i let go of my finger the whole unit seems to chatter and skip. It only happens some of the time, and mostly when I am traveling longer distances. It is creating me to XY home to get the same location. Is this a common thing that happens?
    I also have a desktop model and I have never seen or heard this happen on that unit.
    Let me know your thoughts
    Adam
    Cleveland TN
    Adam,
    I don't have a Buddy but if you call shopbot they will get you fixed up right away.
    Joe
    2005 PRT Alpha 48x96
    2013 Colombo 3hp spindle
    Indexer (converted lathe)
    Aspire 9.0
    Jul 2011
    Timmins, Ontario, Canada
    Quote Originally Posted by Adam Buchwald View Post
    Hi-
    ...Is this a common thing that happens?
    Adam
    Absolutely not. I have had my BT48 (alpha) Since Feb 2012 and have kept it upgraded to the latest software/firmware. Never experienced this even once.
    Nov 2014
    Knoxville TN
    Adam, I had the same thing on my unit and was told bad pinions, bad rails, etc. I wound up replacing 2 driver IC's and 2 Diodes and the problem was fixed. Now it purs like a kitten. It is not the easiest process, but I have a electronics engineering degree, that I haven't used in 20 years, and it still took me a full day to fix. Let me know if you have any questions.
  1. Drifting Skipping Axis?
    By verhoevc in forum ShopBot Desktop
    Last Post: 03-07-2019, 01:55 PM
  2. Movie About the Z-axis Skipping
    By Chazz in forum ShopBot Desktop
    Last Post: 08-04-2015, 08:53 PM
  3. X-Axis is Jittery/Skipping
    By MitchTalmadge in forum Troubleshooting
    Last Post: 10-14-2014, 07:43 PM
  4. Z axis skipping
    By BulletTrap in forum ShopBotter Message Board
    Last Post: 05-06-2010, 10:01 AM
  5. X axis binding/chattering/locking up on entire rail.
    By prolitesigns in forum Archives2008
    Last Post: 06-18-2008, 03:13 PM
