Thread: Feed Rate, Plunge Rate, RPM
    Feb 2015
    Union, NJ
    Default Feed Rate, Plunge Rate, RPM
    Hello I have PVC material and am trying to cut out letters. I have a onsrud 1/8" upspirle. Im only using this to cut the insides of "a" and clean up small ariaes where the 1/4" wont fit. Please advise as to Feed Rate, Plunge Rate, and RPMs, I am useing aspire if that make any difference. Thank you.
    Apr 2011
    New Jersey
    75-100ipm. 20-30ipm plunge. DOC = .125-.25. RPM ~ 13,000 RPM (two flute). 13-18,000 on an "O" Flute.
    I've found slower, with more aggressive depths work best. Varying RPM hasn't made a significant difference on cut quality but you want to bump the RPM on an "O" flute bit. If bumping the RPM causes issues, then slow down the machine a bit.
  1. Feed Rate vs Toolpath
    By Steve Wonser in forum ShopBot Desktop
    Last Post: 06-08-2015, 02:42 AM
  2. Feed Rate Changes
    By John Murray in forum Troubleshooting
    Last Post: 05-30-2012, 10:39 PM
  3. Feed rate for Plexiglass
    By tracys in forum ShopBotter Message Board
    Last Post: 04-14-2011, 04:30 PM
  4. Plunge Rate Question
    By archis in forum ShopBotter Message Board
    Last Post: 02-06-2011, 01:10 PM
  5. MDF 3/4" Feed rate And RPM's
    By shawnn82 in forum Techniques for Cutting, Drilling, Machining
    Last Post: 03-19-2009, 03:03 PM
