Quote Originally Posted by JamesCar View Post
I wish I could make use of the trial versions but none are compatible with windows 98, so I can't actually put any of the cut files to the shopbot because the trial versions limit the ability to save a file. I'm almost 100% sure I am just going to have to upgrade the control board so I can run my machine from a more capable computer
I'm not sure why you think the current machine can not be controlled by a newer PC. If you are concerned the new PC won't have a serial port, just purchase one:
http://www.amazon.com/StarTech-com-R...erial+pci+card
I think the primary problem here is that you have not clearly explained your problem. There are so many work arounds to the issue you are describing, but you keep shooting them down. Perhaps you should tell us more, so we can assist with something that will solve your problem.
