I'm still struggling with determining feeds and speeds for new cutters that I purchase. In the past I've run into trouble by specifying a feed rate that my machine is capable of, but due to the short length or curves in the toolpath the tool feeds slower than I specified resulting in a change in chip load.
Is there an easy way to determine how a given toolpath will affect the ability of the tool to achieve the specified feed rate?
My machine is capable of 4" per second, how many inches of straight toolpath would be required to ramp up to that speed?
If the toolpath contains curves then how does that affect the actual feed rate?
I've read here that smaller diameter bits like to be run at faster RPMs, but that would require a faster feed rate for a given chip load. I just don't know how to guess at the actual feed rate my machine will use for a given toolpath.
Steve
