Hi All,
I am having problems cutting some aluminum. It's 3/8" 6061 plate and bar stock. I started out using an Onsrud 63-622, 1/4" bit for the first file. I had talked to a rep at Onsrud about pass depth and was using their recommended settings. The first bit snapped.
Pass depth= 0.25"
Feed rate = 250 inches per min
The second bit snapped using the following settings.
Pass depth= 0.25"
Feed rate = 200 inches per min
Having run out of 63-622 bits I switched to a 63-618, 3/16" bit.I set the Pass depth at 0.1875", and the Feed rate at 100 inches per min.
After it had a chance to ramp up "Snap". My last 63-618 bit, settings, Pass depth= 0.09", Feed rate 100 inches per min.It worked, i cut two pieces. I moved on to the next part file using the same settings, and snapped the bit about 3/4 of the way through the file. I was blowing the channel out until it, re-welded itself in the last pass and a half. Obviously too much heat built up. From what i understand i should probably increase the feed rate, but it already sounds like it's at it's limit. I'm thinking a little less pass depth and increase the feed rate. Any help or advice would be appreciated.
Sean.
