We were asked to hang one of our “cookie” style signs with a bracket perpendicular to the building so that it could be seen from both sides… The only way I was comfortable doing this was with threaded rods going the entire distance through the cookie. Our “cookies” are slices of trees (aromatic eastern cedar) and the faces of them are end grain.
This tree slice is 30” in diameter… how do you bore a hole all the way through without wandering off course? Mr. Google said only possible with ship augers as they are constant diameter and self-guide whatever direction they are started at. I could only find 17” ship augers… but wait, they have extensions for them! Bummer, the extension bit clamp is larger diameter than the bit… Why even call it an extension?
To make a long story short… I bought a cable guy installers drill bit… its 54” long with a very flexible shaft designed to be steered around inside walls.
http://www.homedepot.com/p/Milwaukee...-203115398-_-N
With the Bot, I cut a “V” just slightly shallower than the drill bit shank the length of a 20” piece of 2X4. Using the bot to cut this V-groove assured that the slot was parallel to the table. After inserting the drill bit in the V- slot, I screwed a 2X4 on top of it. I could vary the slop of the bit in the “V” by how tight I screwed it down.
I’m amazed! I can reliably, predictably and accurately drill the entire width of the cookie!
