I think it is on the fourth pass from left to right (just before I stopped the cut). On the previous passes you will see that I ramp it up towards the end of the run. On the last left to right pass, you can see that it starts to ramp up; but that an additional sound can be heard and the router does not climb but rather kind of stutters but remains basically level. Then the cut starts the right to left swing and cuts deeper and basically chops up the test wood.
With regards to the hold-downs. I have evolved over the years. This test material has been bolted down for I guess about a month as I have shifted my attention to life issues. To boot, the part happens to be over one of my first spoiler board damaging mistakes -- yes, this is my original spoiler board. There was a small amount of gap even when it was over an inch thick; but the time did cause it to curl up a touch. The flexing that you see didn't happen on the original cutting.
I like the idea of trying to manually run it up and down with pressure on it in each direction. I wish I had a scale to measure the actual pull in any given direction. Do you have any ballpark weight that should be considered "good"?
Chazz
