Livermore, CA . For Sale: see picts
2005 120x60x6" PRTAlpha with prox switch
(This size allows you to work two sheets of Baltic Birch at once)
3hp Colombo Spindle
6" Alpha Index head
My table has been designed to provide an 18"x18"x10' space with adjustable spacing to make use of this head. see picts.
z-zero plate
3-d probe
JDS Canister VAC, 1.5HP 110/220v two port (4") with remote ac switch
Fein Turbo II vac for "Bill Palumbo" vac hold down system along with strategic "thru holes" to enable bolting for hold down.
My table has 5 zones for vacuum control
Welded 6" I beam steel table
(Table has I beam wheel set to allow transport so there will be no need to disassemble...Control box is mounted on 4x8 ply that can be put on top of table without removing wires and with gantry secured, pulled onto a flatbed tow truck and driven to new home...Just attach power and get going....)
Computer, flat screen monitor, and table go with. shopbot soft go with.
Miscellaneous router bits and extras will be included.
((I also have for sale, DelCams ArtCam Pro 8...I will list it separately It is upgradable to version 16 for $2500.00....$3000.00 to me and you save $2,000.00 off their list price.))
The spindle was always warmed up before start...Lubed regularly with white lithium.. Relatively low hours as it sat in storage for two+ years.... My dreams and physical abilities have changed...Hope it can find a new dreamer....
A new PRS Apha with comparable size and gear ( that's with just a flat table) would run w tax: $33,751.
$24,000 Cell 925-364-0643
