Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Vacuum Pump
    Oct 2007
    Default Vacuum Pump
    I have struggled with everything from screws to clamps to double sided tape with mixed results. Here is what I hope will be the best resolution. I used the design Bill Palumbo describes on his web site. Thanks Bill for sharing your design.
    Oct 2000
    Toms River, New Jersey
    Mike,
    It looks good ! In fact it's a neater, tighter setup than my original prototype.Add a few pods/pucks, and you're in business...!
    Oct 2007
    Thanks Bill. Your design is great. One question: in the "out" port on your pump there is something black attached is that a filter or some type of muffler?
    Oct 2000
    Mike,
    It's an "exhaust muffler" and I got it from -www.veneersupplies.com ( same people as www.joewoodworker.com)It costs about $2.75, and they claim it reduces pump noise between 17-22 Db.
    Oct 2007
    Thanks Bill, I have one on the way.
    Feb 2007
    , Chardon Ohio
    I,am in the process of building a simular set-up with the same vacumn pump. How were you able to wire the system with a 220 pump and 110 mac value.
    Apr 2007
    Marquette, MI
    Steve...
    IF you are going to mix 120V and 240V on one cord you should use a 4 wire cord, plug & receptacle. (code)
    Joe woodworker has mac valves in both 120 and 240 versions. I recommend using the relay as they show on the site. even with low draw motors, you get a better safer action with the relay rather than simply switching one of the hot legs of a 240V circuit with a vac switch. If you do use the relay and have a neutral present, then you will be able to switch a 120V MAC valve also. (120V or 240V) IF you need diagrams beyond what is available on joes site, email me.
    Gary
    Mar 2008
    Radford VA
    Is this type of vacuum pump setup mainly for use with pods? I want to do my 4 x 8 table with maybe 8 zones pulling through Trupan. My initial plan was to just get a Fein vac for the vacuum source. But the Fein is $450 and the vacuum pump setup above looks to be much cheaper. Is the Gast pump setup appropriate for spoilboard use?
    Jul 2007
    LM Custom Woodcrafts, Cortlandt Manor New York
    You won't have enough CFM with that type of pump for a whole table/spoilboard. Shop around - I've seen the Feins for closer to 350-375.
    Mar 2008
    Radford VA
    Lou - I did some shopping, the best that I can find is $409 so far. Do you happen to remember where you may have seen the $350 - $375 prices?
  1. Vacuum Pump
    By dmidkiff in forum ShopBotter Message Board
    Last Post: 05-15-2014, 08:29 AM
  2. Vacuum pump
    By mars in forum ShopBot Accessories
    Last Post: 09-08-2013, 04:49 PM
  3. Vacuum pump
    By tomahack in forum Archives2008
    Last Post: 11-28-2008, 03:40 PM
  4. Vacuum Pump
    By frank_hav in forum Archives2007
    Last Post: 03-27-2007, 12:53 PM
  5. vacuum pump
    By param in forum Archives2006
    Last Post: 05-24-2006, 07:15 PM
