Results 11 to 20 of 25
Thread: E-Stop woes have come to visit me
  1. #11
    Joe,
    That is OK. I thought your tool was newer or Alpha with the 24v stuff. Do the proxies themselves light up when your control box is on?
  2. #12
    Jun 2007
    Hampton Roads, VA
    They don't.
    Today I have some bread for a new MM. If the hurricane doesn't cause everything to close. There is a lot of flooding in my area for the last 3 days. I will check the 12V, 5V, and make sure the grounds for the board, control box, and the machine are the same.
  3. #13
    If they are the barrel type 'Baumer' prox switches, and they are not obstructed at the tip with metal, they should be lighting up.
    Pull out the connection to the prox wires at the blue terminal strip, and re-seat each one.
    You either have a bad connection, or a broken wire.
  4. #14
    Jun 2007
    Hampton Roads, VA
    electrical panel Ground = bot chassis = board grnd
    5VDC = 5.00VDC
    12VDC = 11.21VDC
    Is 11.2VDC (~7% off ) within tolerance for a proper digital break over? Can I still get a PS from SB. Do I need to?
  5. #15
    cnc routing, portland or
    I had a wire break somewhere on the y stop and finally just replaced the whole thing with a new one I had on hand. both light up butI can't get them to trigger the software now. lready 1pm and have not worked at all.
  6. #16
    Quote Originally Posted by khaos View Post
    Seems pretty low & out of tolerance, in my experience. I would consider it bad if in the field.
    If you have the blue Lutze PS, they should still have them.
  7. #17
    Jun 2007
    Hampton Roads, VA
    I'll call them tomorrow. That PS had a good run.
  8. #18
    of course after it not working all day yesterday it is working today.
  9. #19
    Jun 2007
    Hampton Roads, VA
    So talked to tech sup and I tried resetting all my values to factory. That didn't work... I will get back on the phone tomorrow if I can get back to the shop at a reasonable hour.
  10. #20
    I am almost thinking mine is time the machine is off or left alone.
  1. Mc Grew Camp and Dana Swift visit
    By Ken Sully in forum ShopBotter Message Board
    Last Post: 05-07-2015, 05:18 PM
  2. ShopBot Visit in Maine
    By pappybaynes in forum ShopBotter Message Board
    Last Post: 10-12-2014, 08:53 AM
  3. Top 10 Geeky Projects to earn yourself a Memorial Day ER visit
    By srwtlc in forum ShopBotter Message Board
    Last Post: 05-31-2011, 06:28 PM
  4. Blog posting about a visit to Rob Bell's shop
    By bill.young in forum ShopBotter Message Board
    Last Post: 05-13-2009, 03:30 PM
  5. Visit to a Demo'd Customer
    By birdsofplay in forum Archives - thru 2002
    Last Post: 10-07-2000, 10:57 PM
