Results 1 to 5 of 5
Thread: Freezing On a Jog
    Mar 2015
    Groton, CT
    Default Freezing On a Jog
    My BT48 Buddy is consistently freezing on certain jogs after cutting holes.
    In the example below it cuts fine to line 48. It completes the CG but stalls out, eventually timing out. At which time a "Location Matched to Tool..." message appears and a quick jump to "--Unexpected Return Fault--".
    The CG executes but the J3 does not.
    I Quit and then rerun starting at line 49, and it continues no problem until line 65 where I have a similar CG line followed by a J3 where it stops again. I have a series of these holes followed by jogs and it stops the same way at every one. Once it paused for a while before regaining its composure and moving on, but otherwise it has stopped at every similar combination of G-Code, and I've had similar problems on other cut files.
    The problem does not occur when the router is turned off for a dry run, but does recur when the router is on but there is no material to be cut.
    Any suggestions?
    Nick
    [CODE]'----------------------------------------------------------------
    'SHOPBOT ROUTER FILE IN INCHES
    'GENERATED BY PARTWorks
    'Minimum extent in X = 0.000 Minimum extent in Y = 0.000 Minimum extent in Z = -1.000
    'Maximum extent in X = 6.000 Maximum extent in Y = 30.846 Maximum extent in Z = 0.000
    'Length of material in X = 6.000
    'Length of material in Y = 30.846
    'Depth of material in Z = 1.000
    'Home Position Information = Bottom Left Corner, Material Surface
    'Home X = 0.000000 Home Y = 0.000000 Home Z = 0.800000
    'Rapid clearance gap or Safe Z = 0.200
    'UNITS:Inches
    IF %(25)=1 THEN GOTO UNIT_ERROR 'check to see software is set to standard
    SA 'Set program to absolute coordinate mode
    CN, 90
    'New Path
    'Toolpath Name = Countersink Predrill
    'Tool Name = 1/4" Down-cut (57-910)
    &PWSafeZ = 0.200
    &PWZorigin = Material Surface
    &PWMaterial = 1.000
    '&ToolName = "1/4" Down-cut (57-910)"
    &Tool =3 'Tool number to change to
    C9 'Change tool
    TR,12000 'Set spindle RPM
    C6 'Spindle on
    PAUSE 2
    MS,3.0,2.0
    JZ,0.800000
    J3,3.576650,1.896842,0.200000
    M3,3.576650,1.896842,-0.125000
    CG, ,3.701650,1.771842,0.125000,0.000000,T,-1
    CG, ,3.826650,1.896842,0.000000,0.125000,T,-1
    CG, ,3.701650,2.021842,-0.125000,0.000000,T,-1
    CG, ,3.576650,1.896842,0.000000,-0.125000,T,-1
    M3,3.576650,1.896842,-0.250000
    M3,3.576650,1.896842,-0.375000
    J3,3.232283,3.530674,0.200000
    M3,3.232283,3.530674,-0.125000
    CG, ,3.357283,3.655674,0.000000,0.125000,T,-1
    CG, ,3.232283,3.780674,-0.125000,0.000000,T,-1
    CG, ,3.107283,3.655674,0.000000,-0.125000,T,-1
    CG, ,3.232283,3.530674,0.125000,0.000000,T,-1
    M3,3.232283,3.530674,-0.250000
    M3,3.232283,3.530674,-0.375000
    J3,3.957556,5.157669,0.200000
    M3,3.957556,5.157669,-0.125000
    [/CODE]
    The first thing I see, is the MS @ 3,2; Specifically the 3" per second XY parameter. You have to take care not to defy the laws of physics...
    You aren't going to go 3 IPS cutting the inside of a 0.25" circle. SB3 will try to reduce speeds to compensate for improper programming speeds, but putting the right speeds in from the start is the preferred method.
    Try changing your speeds to: MS,0.5,1 and see if this makes a difference.
    Mar 2015
    Groton, CT
    Thanks. It seems to help. Any idea why it would matter that the router is turned on vs off?
    I don't know. I would imagine that it is possible that the router is sucking some good amps from that circuit and possibly limiting the maximum available power to the stepper motors. This may be more prevalent if the brushes are on their way out.
    It might be an interesting test to plug the router into a completely different circuit and see if that is the case.
    Another thing to look at is, what version of SB3 are you running? There were some earlier versions of 3.8.XX that when one part of the file was finished cutting and it raised up to jog to the next part of the cut, it would stall or go off course after a bit. This would also happen more often on certain MS combinations like 2,1 and a few others. If you're running an earlier 3.8.XX version, I'd update to the latest version of 3.8.36.
    "It’s easier to fool everyone than it is to convince them they've been fooled" - Mark Twain
  1. Bot Freezing Up?
    By creative_cabinetry in forum ShopBotter Message Board
    Last Post: 06-12-2013, 12:29 PM
  2. Spindle RPM Tool Freezing Up
    By jdervin in forum ShopBot Accessories
    Last Post: 03-11-2011, 08:01 PM
  3. Bot freezing under v3.5.3
    By geneb in forum Archives2008
    Last Post: 04-22-2008, 10:10 PM
  4. Parts wizard 2 freezing up
    By oddcoach in forum Archives2006
    Last Post: 08-31-2006, 08:04 PM
