hello, i need to cut out several simple 10" diameter rings out of flimsy aluminum sheet metal. these rings will also have 1/8" holes drilled out along the center of the ring. so i was hoping to use an 1/8" diameter bit for the drilling and cutting so i don't have to do a tool change. i have my original shopbot starter set Onsrud 77-102 bit. i never used it. it appears to be an upcut spiral. can i use this bit for drilling/cutting and if so what feed rate and spindle rpm? or if i shouldn't use that bit, what do you guys recommend? thanks!
