Mystery stopping of PRT, crazy restart!! Help
Hello Shopbot Friends:
In cutting out a previously posted flower image from an 8 foot long, 12" wide 3/4" PVC board, I was maybe 15 minutes into cutting with a 1/4" bit, when the Bot stopped. The screen display was flashing, and the error message said: "!!! TOOL STOP BUTTON ON!!!".
Well, the button wasn't pressed, I was just glancing that way, when the BOT stopped. I wasn't vacuuming, or even moving.
So I went to the PC, and it told me that the cut file had stopped at line 4738. I figured that instead of restarting the file from the very beginning, that I would see if I could figure out how to make the file resume where it had left off. (I hadn't touched or moved anything on the Bot since it suddenly stopped. The spindle was sitting right where it was when the Bot stopped.)
My BOT cheat sheet led me to the FG command. It asked for a line number, which I entered. Then it asked me if I wanted to resume from that point, or if I wanted to single step. I selected resume, then hit the start button, and in 20 seconds, the spinning bit plowed into the flower and cut a 1/2" groove in the WRONG place, before I hit the STOP button. (Where it cut, was not even a logical place, compared to the following error.)
So, I hit myself in the head, and said I should have just restarted from the beginning, instead of trying to be cleaver!
After restarting the SB3 control PC interface, I reloaded my original file from the flash drive, and hit start. In maybe 15 seconds of starting, the spinning bit cut into something that it should not have. (It was cutting in the right place, but was cutting maybe 1/4" too deep.)
Questions:
1) Why would my Bot suddenly stop, claiming that the Stop Button had been pressed when it had not been pressed? (I don't think I have ever had this happen before. But I have occasionally had my Bot stop when it said I had exceeded the table limits when I was nowhere near. In those cases, I was given the choice of continuing or not, and it worked fine.)
2) How should I have restarted the cut file from where it had mysteriously quit?
3) Why would things get fouled up after RELOADING my cut-file? (This is the most troubling of these mysteries! I had this would be a sure fire way to get back to normal.)
Thanks, Chuck
PS: I had already run this cut file on an identical board yesterday, without any problem.
Reason: added PS
Chuck Keysor (circa 1956)
Columbo 5HP spindle
Aspire 9.0, Rhino 5
