Results 1 to 10 of 10
Thread: Masking on PVC for V carve
    Norman, Ok
    Default Masking on PVC for V carve
    Does anyone have experience with masking and V carving HD PVC. So far we've used Gerber Mask and Avery. Both do a fair job but when it gets to the fine details they give way.
    The next step would be to try intermediate vinyl. What we're wanting to do is paint or gild the well of the letters.
    Joe
    Sep 2012
    Blaine Mn
    I have had good luck V carving with intermediate that has been laminated. We have tons of scraps from the printer. We use Orajet 3551RA (air release)
    and it sticks fine. It thought you retired? I retired 6 years ago and cut back to about 60 hours a week. The longest I have been away was one month (last year) and I was gettin' jiggy to get back and touch all my tools and stuff. Gene
    May 2005
    Londonderry New Hampshire
    I have done 50+ "PVC" historical signs with Oramask...works great!
    Dick
    Aspire 8
    Jan 2015
    Houston Texas
    What's the difference In using pvc vs HDU?
    Choose a job you love, and you will never have to work a day in your life.
    Delray Beach, FL
    Davo:
    Google "difference between..........."
    and you will learn all you want!
    Jan 2015
    Houston Texas
    Well... That lead me back here... Go figure
    Good post about it
    http://www.talkshopbot.com/forum/sho...MDF-HDU-or-PVC
    Delray Beach, FL
    Thought you would get a kick out of that!
    Norman, Ok
    For those who don't know, most PVC is interior grade and not recommended for outdoor use. It's famous for warping and bending under heat. What you will need is the High Density stock and it only comes in .75" & 1". That's the only way I've found it. My favorite brand is PALIGHT. One way you can tell if you're getting the HD type is the lack of surface texture. If there's any at all you have the wrong stuff.
    Joe
    Quote Originally Posted by joe View Post
    Me too...If you can find it.
    Many may not know, but the exterior PVC trim boards are made at the same plant as the large 4x8 sheets. This is true for Kommerling anyway. There was a while there when 4x8 sheets in certain thicknesses were unobtanium because they were tooled up to extrude the exterior trim boards. The stuff seems OK in smaller sections, but as Joe points out, it gets all wally in the heat and the larger the panel, the worse it is.
    Aug 2013
    Clayton, NC
    Joe
    Thanks for info, just googled them, seems they now offer it with wood grain finish:
    "PALIGHT® Outdoor is a versatile, lightweight and durable foamed PVC sheet that is ideal for outdoor signage and display applications. PALIGHT offers an excellent white color and a smooth or wood grain finish."
    In your experience with it, can it be free hanging or does it need a backer used to prevent warping / bending?
    Daniel E.
    Porter Cable Router
    Vacuum Table w/ 2 Fein vacs
    Aspire 9.0
  1. Masking
    By joe in forum Sign Making
    Last Post: 04-13-2016, 12:15 PM
  2. Masking Techniques
    Last Post: 09-27-2013, 01:46 PM
  3. Correct way to pull up masking after V carve
    By nick in forum Archives2008
    Last Post: 09-17-2008, 08:32 PM
  4. Masking Question
    By fleinbach in forum Archives2007
    Last Post: 12-02-2007, 12:36 PM
  5. Help with masking for machining
    By Rookie432@aol.com in forum Archives2005
    Last Post: 07-19-2005, 07:32 PM
