quick change spindle
Okay, its been a while since my last post,several months actually. Ive been busy learning to operate and doing some upgrades on my PRS Alpha. After a few months of processing parts and inumberable z zero operations, I finally updated the software to take advantage of the bit change without rezeroing the z axis. This is the main advantage of the quick change spindle.
I currently have three HSK toolholders which can be programmed into the sb control software and take advantage of atc tool changes. Today Ryan and I programmed tooling for two of my tool holders and allows me to change bits while running a cut file without doing a z zero operation.
After doing tool changes the regular, mtc way for several months, I have a definate appreciation for atc style tool changes. Most of my cutting involves one bit and air drill for drilling pilot holes. A couple of times a week I run mdf doors which requires a tool change after I run the center panel profile bit. The next time I run them, I will be able to switch between the two bits and run muliple sheets without having to do a z zero operation.
Today, after cutting some plywood and melamine with a 3/8" spiral compression, I was able to switch over to a 3/16" downspiral and cut out some cardboard for shipping boxes and then back to 3/8" compression without zeroing. It was pretty nice and much more convenient than dragging out the zero plate and alligator clip and hooking up to bit and zeroing the bit after changing.
Next week, Im sure I will have some doors to cut out and more atc style tool changes and gain more appreciation for the quick change spindle!
Have a Great weekend!
PRS Alpha 96-60
HSD 4hp Quick change spindle, HSK toolholders
Air Drill
6 zone vacuum table
