Results 1 to 4 of 4
Thread: crv files can no longer be opened by older versions
    Cleveland TN
    Default crv files can no longer be opened by older versions
    Just as an FYI, I was attempting to assist a member by sharing a file, he has VcarvePro7.5. He was unable to open my crv file so finally I fired off an email to Vectric concerning this (I have 8.024, doesn't matter if it is VcarvePro or Aspire, I tried both) and this is the reply:
    Hello Joe,
    You will not be able to save a CRV file that they could open, I am afraid, but you would be able to export out any vectors as a DXF file (Ctrl +A to select all the vectors).
    "File > Export > Selected Vectors to DXF"
    I hope that this helps.
    Regards,
    Mark.
    Mark MORAN
    Support Manager
    2005 PRT Alpha 48x96
    2013 Colombo 3hp spindle
    Indexer (converted lathe)
    Aspire 9.0
    Yes. You cannot open a v8 file if you are only running v7.5.
    However, you can open a v7.5, if you have v8. This is how it's been since the beginning.
    As Mark points out, select the vectors and export them as an EPS or DXF. Then he can import them into his version. You won't be able to transfer the toolpaths, but that usually isn't a big deal.
    Nov 2008
    , On
    Too bad... Lots of graphics programs let you "save as" older versions.
    Jun 2012
    Ohio
    This isn't something new, and it certainly isn't an Aspire exclusive.
    The way they've handled it is pretty much an industry-wide standard.
    Heck, in many instances, new platforms aren't backwards compatible at all.
    I was aware of this right out the gate because the free projects Vectric posts are always done in the latest software.
    So I won't be able to grab any of those freebies anymore.
  1. Timeline of Buddy Versions?
    By rtfosmoe in forum ShopBot Buddy
    Last Post: 07-04-2014, 11:19 PM
  2. Maybe not Longer
    By angus_hines in forum ShopBotter Message Board
    Last Post: 02-03-2009, 01:11 PM
  3. Notification of new versions
    By chamcook in forum Archives thru2004
    Last Post: 02-26-2004, 11:28 AM
  4. No longer a 'Wannabe'
    By robinsoncr@naxs.net in forum Archives 2003
    Last Post: 05-12-2003, 09:49 AM
  5. Longer collet?
    By greg@germanguitars.com in forum Archives thru 2002
    Last Post: 11-19-2001, 03:21 PM
