Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Having problems creating this 2 rail sweep
  1. #11
    May 2009
    Portland, OR
    Brady
    Thanks, So for the box top, which I believe would be considered a positive 3d shape, I am asking the 2 rail sweep to machine down from tip to ridge at an angle on both sides, in order to make the shape. Shape height is .3937, and model has been placed at the top of material block. no problems there.
    Next, I am asking the software to machine down to that same .3937 depth with a pocket labeled "Outside of ridge"
    This is where, when previewed, the depth of the outside of ridge is deeper than the depth of the "3d model, even though I have asked to machine to the very same depth. Why the inconsistency with depths, when I am entering the same value for both?
    Long story short, I want the depth of the pointed 3d shape to match the depth of the out side ridge, and they are different, but need to be the same. Thanks
  2. #12
    May 2009
    Philadelphia PA
    Since you have your Z from the top of the material, you are tell the machine to cut the 3-D component from the top down...
    Next you are asking to cut a profile cut that will be .3937 down from the top.
    This is why you are getting that lower outside edge.
    Your model height is .3937
    The sides of the model are .2632 tall
    Your cut depth on the profile cut should be .1305
    That should line up your edges,,,except..
    The finish cut is set for the “use selected vectors”
    Your .25” ball end bit will not go down deep enough to meet the .2632 level you are expecting.
    I would create a flat component . 2632, set property to merge and use that outside vector to do the finish cutting.
    You would not need the outside profile cut.
    Here’s a file and some pictures.
    MichaelRING BOX top_1.zip
  3. #13
    May 2009
    Philadelphia PA
    Here's a picture of what I get.
    Michael
  4. #14
    May 2009
    Portland, OR
    Thank You Michael !!!
    Really appreciate this! I will take some time to go back over everything. Thank you to those who helped with file uploading as well.
    Marc
  1. Two rail sweep?
    By jim shula in forum ShopBotter Message Board
    Last Post: 03-06-2014, 08:31 PM
  2. "How To" Videos, Creating Profiles For Two Rail Sweep
    By shilala in forum ShopBotter Message Board
    Last Post: 01-21-2013, 05:23 PM
  3. Two Rail sweep on Indexer
    By kubotaman in forum Indexer
    Last Post: 11-03-2012, 06:13 PM
  4. Two rail sweep
    By kubotaman in forum ShopBotter Message Board
    Last Post: 11-04-2010, 10:32 PM
  5. Rail sweep
    By fishtrap in forum Archives2005
    Last Post: 12-31-2005, 06:04 PM
