you could also cut the shapes slightly larger and then cut the actual size in a single pass to clean it up. I have cut many different foams with ease using a good sharp 2 flute up cut. When I first started I went through every type of bit without even considering the standard 2 flute when nothing else worked I tried it and it was good. I also set up an airline to blow a constant steam of cool air blowing on the bit, It doesn't keep every bit of foam off the flutes but it definatly helps
"The most valuable tool I have is the experience of others" - Me
