Everyone!
I need some expertise. I am relatively new CNC work and the procedures I have followed before are not working. I have been trying to mill the following rosette for over a week now and I cannot get a smooth carving. I have attached two images of an example carving where all of my attempts look basically the same.
I am trying to carve the following from Vectric 3D website: Pattern 58037a (Square Panel 6A)
Here is what I have:
BT32
Porter Cable 7518 router attached
Shopbot Control software - latest version
Shopbot Controller Firmware - latest version
Vcarve Pro Shopbot Edition v8.024 software
Here is what I have attempted:
- Router RPM - 19k & 21k (via Chip Load Calc)
- Feed Rate - 2 in/sec to 7 in/sec (via Chip Load Calc)
- Plunge Rate - 2X bit diameter
- Area Machine Strategy - Normal Offset & 30deg & 45deg Raster (images are 45deg raster)
- Amana Bits - 1/16" (brand new) & 1/8" diameter ballnose (4 flutes each)
- Cutting Parameter: Stepover - 2, 3, 4, 5, 7, & 10%
- Cutting Parameter: Clearance Pass Stepover - 2, 3, 4, 5, 7, & 10%
- 3 different types of wood - Cherry, Pine, & Baltic Birch Plywood
- Collets: Porter Cable Manufactured & Precise Bits High Precision collet for Porter Cable 7518 router
- With & without the dust skirt
Any ideas? You will notice that the striations are not uniform and consistent. I have never had this problem before. Everything I have tried is producing the same issue.
Let me know.
Thanks!
Hutchie
