Results 1 to 9 of 9
Thread: Aspire 8 problem
    Oct 2014
    La Crosse, Wisconsin
    Default Aspire 8 problem
    Everything has been going on just fine till now. Two different computers two or three different system available vetrics file panels all with the same error.
    Everything seems fine but finish 3d panel cut when watched closely has a uncut shape (differs from one file shape to the next) the shape goes away at the end of the cutting preview but it shows up when cutting the panel in the bot and does not go away.
    See the two attached pictures.
    Check that the vector used for the machining boundary is clean and closed with no open parts or loops.
    Feb 2010
    SOUTH CENTRAL COLORADO
    is the file ok to post on here.
    Oct 2014
    I only have a 3D finish pass on it now as that is the operation giving me problems. I took out all the rest of the 3D objects and the v-carve etc just to be sure.
    File is too large to attached here.
    Oct 2014
    It wouldn't be the boundary lines etc as it's Aspire's own vetric files and it's happening with more that one panel design puled in directly from the Aspire 8 program.
    Fredrick,
    Running the latest Aspire?(Think it's 8.024 like VCP8?)
    Oct 2014
    Yup 8.024 windows 7 on my putter windows 10 on wife's same results on either. I'm suspecting that Aspire has some vetric file programming issues.
    Oct 2014
    Wife seems to have found the fix if not the reason for our issue. Except for roughing cuts we have been exclusively using the offset cutting option. Changing to the raster cut option for the finish cut makes the unwanted material go away. Still thinking it's a Aspire issue but maybe not vector related so much as a basic programming glitch
    You may want to post your original post on the Vectric forum and send the file to Vectric Support Fredrick?
    Always nice to be able to cut the way you want to if possible, and personally just Hate not knowing "WHY?"
    VERY helpful folks at Vectric, but it is the weekend. Very possible someone of Forum has run across it.
    Smart Wife
  1. Aspire problem
    By banjomanwv in forum ShopBot Desktop
    Last Post: 06-15-2015, 12:34 AM
  2. pause problem and symmetry problem
    By amholtin in forum Troubleshooting
    Last Post: 10-08-2013, 02:07 PM
  3. Aspire
    By jimmya in forum ShopBotter Message Board
    Last Post: 10-26-2010, 07:55 PM
  4. Problem between aspire and shopbot
    By frank134 in forum ShopBotter Message Board
    Last Post: 02-04-2010, 07:00 PM
  5. 1st original Aspire work - 2nd Aspire project
    By nailzscott in forum Folder 2009
    Last Post: 02-26-2009, 04:09 PM
