I have an old 5'x10' PRT that dates back to 2003 (that's a guess, I bought it used). Although I occasionally use the 5' width capacity when I cut 5'x5' baltic birch, I've never had a case where I needed the 10' length capacity. I'm thinking about cutting 2' off it to gain a little shop space. The rails are the blue steel angle with the geared teeth on the bottom edge. I'd like to shorten the length without taking it all apart. So if I cut it in place, what's the best way to cut that hardened steel?
