If it had 202 and you changed them over to 203 I guess you need to change the jumper from the original setting. I'm not versed in shopbot boards but have worked with almost every gecko drive. your settings for steps per will stay the same because both drives are 10X or 2000 steppes per revolution (motor not gear head). Gecko has had problem with the connectors that the drives plugin to even though they would not say so. Gecko is one of the finest drive in my book.
