The Buddy is intended for those who might need to tuck the Bot in the corner of the shop when not in use, or to do a large variety of smaller jobs.
Because the table isn't fixed, vacuum hold down systems seem to move a few 0.001's" each time we take that hold down on and off the power stick deck. [this Buddy has no aluminum table component]
We've resurfaced the spoil board a few times but still seem to get some twist, warp, cup or bow every time this fixture is reinstalled.
Has anyone considered making a egg crate/pigeon hole hollow plenum, one with 1-1/2" of depth? My thinking is to build a fixture that was rigid by itself not relying on ply and MDF sandwiches. Instead, of making the plenum form sheet goods what about framing a glued up 2" [deep] hollow of 1-1/2" x 1/4" slats notched to a 1-1/2" gird inside a sheet of 1/2" bottom and trupan or mdf top?
My goal is to have a 'quick change' from one hold down system to another that would retain the surface closer to flat - but not depend on the Bot's table for structure.
I'm cutting plastic labels for industrial control panels and the lettering is turning out thicker and thinner due to irregularities in our current version; copied in miniature from the larger fixed table plenums shown on the Forum.
If anyone cuts labels with a Buddy model 'Bot, I'd sure appreciate learning about their hold down system.
cheers,
Kevin Morin
