Results 1 to 8 of 8
Thread: Running multiple tool paths on one job (V-Carve)
    Aug 2015
    NY
    Default Running multiple tool paths on one job (V-Carve)
    Hellos all!!
    Im trying to find information on running multiple tool paths. I thought I saw something on here about it. :/
    Want to run all my tool paths for a job. Multiple pockets of different size /shape/depth. All use the same bit.
    Also, if I have a pocket within a pocket. Is there a way to have the deeper pocket gor straight to the material instead of the bit not contacting material till its gone through empty passes?
    Hope everyone is having a good day!!
    Thanks!!
    Feb 2013
    River Fall WI
    To the pocket in a pocket, Yes.
    You may want to post your files or at least a picture of what you are going for, as there are many ways to do things depending on the project.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Delray Beach, FL
    How to pocket in a pocket:
    Create a separate toolpath for the pocket in a pocket. Set the start depth to where the material is after cutting the first, shallower pocket.
    You can set up a pocket toolpath for all cutouts of the same depth but can't have more than one depth in a single toolpath.
    If you are asking about saving all your toolpaths to one SB file then click on the file save icon and check the box at the top.
    From there you should get it.
    Vectric tutorials are very good. You should work through them.
    Aug 2015
    NY
    I tried saving all the toolpaths in one. But then when I run the job, it only cuts one of them.
    Kyle this is the housing im making
    Feb 2013
    River Fall WI
    How big is that part? What are the stepdown sizes?
    What is it made from?
    What bit are you going to use?
    Sorry for all the question, but the more info the bester the answer.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Delray Beach, FL
    Can you post a screen shot showing the object and the toolpath dialogue when you are ready to save it?
    When you save your file make sure you have output all tool paths checked. To pocket inside a pocket I would do the deep one first the offset the shallower inside one into the deeper pocket by half the diameter of your bit. That way you are only cutting once.
    Mar 2016
    Silicon Valley
    In V-Carve you have to differentiate between toolpaths that have checkmarks next to them, and toolpaths that are in BOLD. I falsely assumed that if it was checkmarked it was going to get saved in the G-Code file, WRONG. Vectric V-Carve looks at the bold selection state. Be sure to open your G-Code Shopbot Text file and verify you see multiple Toolpaths.
  1. V carve using multiple bits
    By dstacey in forum Sign Making
    Last Post: 11-29-2011, 09:52 PM
  2. V-carve tool paths - Long Machine Times
    Last Post: 04-23-2011, 05:00 PM
  3. Tool paths
    By matney_models in forum ShopBotter Message Board
    Last Post: 07-12-2010, 09:46 AM
  4. Running a file multiple times
    By andyb in forum Developers
    Last Post: 08-06-2008, 09:56 AM
  5. Tool Paths?
    By jimmythethief in forum Archives 2003
    Last Post: 09-23-2003, 02:03 PM
